S&S Quickee Adjustment
Old 01-04-2023 | 04:36 PM
brownie4412's Avatar
brownie4412
Originally Posted by Mchad
Oh that's pretty cool. I was looking at tapered-sized ones but the ones I saw were one piece - i.e. no slot to get them around the rods. They don't show 4.250 for my soon to be 124 M8 pistons on their online store though. I'll give them a call to see. THANKS!
If they can’t help you out, I have a brand new Jim’s set that I’ve never used. I don’t remember how big it goes… but if you’re interested let me know
Old 01-04-2023 | 04:42 PM
Mchad's Avatar
Mchad
I will, thank you.
Old 01-05-2023 | 01:49 PM
snake_eyes's Avatar
snake_eyes
Alright, lifters are here from FuelMoto. Can I just use the same oil that's going in the case to pump them up?
NEWROADSTER (01-05-2023)
Old 01-05-2023 | 02:01 PM
Mchad's Avatar
Mchad
I always do... Some try being tricky using light weight oil so the bleed down faster but what does that save you? A couple minutes? Use what's in your pan...
The following 3 users liked this post by Mchad:
Dan89FLSTC (01-05-2023), pgreer (01-05-2023), snake_eyes (01-05-2023)
Old 01-05-2023 | 04:01 PM
John CC's Avatar
John CC
OK, maybe a dumb question, but, why pump them up if the next step is to force them to bleed down?
Old 01-05-2023 | 04:03 PM
snake_eyes's Avatar
snake_eyes
Without the oil pressure it's next to impossible (for me at least) to get zero lash on the pushrods before extending them to the correct length.
Old 01-05-2023 | 04:05 PM
John CC's Avatar
John CC
OK, makes sense.
Old 01-05-2023 | 07:04 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Little advice on high lift cams and quickie pushrods. I had to cut the upper tubes shorter to keep the pushrod collars from hitting the upper tube making it sound like a lifter tic.. I have a thread around here some where with pictures of the damage.. I measured each one because they were all different, I believe from .250-.370". Easily shortened with a rigid copper pipe cutter..
brownie4412 (01-05-2023)
Old 01-06-2023 | 10:40 AM
Mchad's Avatar
Mchad
Just to follow up (and continue to derail this thread - sorry) - they just emailed me back saying they were in production and were about 2 weeks out with availability. Which is fine for my schedule. So no need, but appreciated as always.
brownie4412 (01-06-2023)
Old 01-06-2023 | 10:47 AM
snake_eyes's Avatar
snake_eyes
Thanks for the tip, I'll check that out when I get all the parts and tools in hand.
