Wheel Bearing Recommendations
#31
$34.69/ea., does that seem about right?
Timken 6205-2RS - Motion (motionindustries.com)
#33
Took me a minute, but here's the thread with the photo I posted comparing OE to All ***** to Timken. Based on what I posted then (back in 2015) I used the Timken 205PP bearings on my non-ABS '09.
https://www.hdforums.com/forum/dyna-...acement-3.html
Not sure what the difference is between the 205PP and 6205-2RS.
https://cad.timken.com/item/deep-gro...0--64/6205-2rs
https://cad.timken.com/item/deep-gro...k--200k-/205pp
#34
#35
Very informative, thanks guys! So, is Timken a brand of constructed bearing or the internal parts that other companies can use to produce a bearing? Also, what about the other letters that can follow RS? I've seen RS-JEM and several others. I really appreciate the info; this is one area of mechanics that I never worked in, so I don't know much.
The following 2 users liked this post by LQQK_OUT:
snake_eyes (11-06-2022),
sonny4 (11-05-2022)
#36
I went with all ***** 2 years ago and can actually feel a slight vibration when cornering, left or right.. I will go with Timkens this winter..
I use a Pit Posse kit. Does 3/4, 1" and 25mm. Never an issue.. I paid a little over $100 for it..
sonny4 (11-05-2022)
#37
How many wheels have you done without issue?? Did you check to see if the bearings spun freely after the install?
#38
#39
If you are simply spinning the wheel, you won't see it. You have a 25 inch heavy donut spinning on that bearing. You need to feel the ID of the bearing. I have a kit that came from someplace that made bunch HD special tools. Don't remember there name but they used installers like you have and they killed bearings.. Bearings would last less than one tire change. I had the mentality that the vendor made it, it must work.. It didn't.. If you can check with the guys you installed bearing for and see if they've got a bad attitude about wheel bearings..
98hotrodfatboy (11-05-2022)
#40
