Wheel Bearing Recommendations
2010 fatboy front bearings not much of a issue but rear bearings seem to last about 20,000 miles. Used all ***** brand for awhile until they moved to China. Timken bearings are going in during rebuild. I do my own work and have the proper tools. Would never trust a shop with this job.
Same size as 6205 bearing
Part Number 205PP, Fafnir® Deep Groove Ball Bearings (9100K, 200K, 300K) On The Timken Company
Very informative, thanks guys! So, is Timken a brand of constructed bearing or the internal parts that other companies can use to produce a bearing? Also, what about the other letters that can follow RS? I've seen RS-JEM and several others. I really appreciate the info; this is one area of mechanics that I never worked in, so I don't know much.
Took me a minute, but here's the thread with the photo I posted comparing OE to All ***** to Timken. Based on what I posted then (back in 2015) I used the Timken 205PP bearings on my non-ABS '09.
https://www.hdforums.com/forum/dyna-...acement-3.html
Not sure what the difference is between the 205PP and 6205-2RS.
https://cad.timken.com/item/deep-gro...0--64/6205-2rs
https://cad.timken.com/item/deep-gro...k--200k-/205pp
