Dyna glide front wheels
I have had no luck finding wide front wheels for 16 Low Rider. Need 17x3.5 (preferable) or 16x3.5. A take off of certain models, such as the fab bob would be interesting, but my FXDL uses two front rotors and mid-glide front end. Aftermarket pushes 21" front wheels, never wide stuff. Anybody else have info to offer? Best.
Harleymarlboroman@***.net
Factory spoke mid-glide wheels can have a rotor mounted on either side, but not all aftermarket ones will. A Street Bob/Super Glide Custom take - off spoked wheel would work, even though they only came with 1 rotor from the factory.
The following 2 users liked this post by Reindeer:
Harleymarlboroman (09-23-2022),
Qdog002 (09-23-2022)
But do the SG wheels fit? For example what are the center to center measurement on the front rotors? I need information verifying what we are thinking so that I don't wind up with stuff that I can't use. Everything on Ebay says that it won't fit my bike; doesn't say why, just that it doesn't fit. No help there.
Czracer (09-28-2022)
Here's a 16 X 3.5 FLH wheel on my FXDF. Can be done, but not for most home mechanics...I started by measuring outside to outside on brake rotors to see if it could fit and if not, how close it was. Then it's custom spacers and some hub machining, ensuring rotors are perfectly aligned with calipers AND wheel is centered. I have access to that kind of help otherwise hourly shop fees will apply $$$
The following 3 users liked this post by sharkey:
