View Poll Results: Who would sell there Dyna for a newer bike?
Multiple Choice Poll. Voters: 12. You may not vote on this poll
99 Dyna Wide Glide Battery Issues
Received 20,655 Likes
The following 2 users liked this post by CoolBreeze3646:
BrandonSmith (08-17-2022),
GREENOHAWK69 (08-17-2022)
Received 5,222 Likes
I had this same issue, I don’t get to ride much so I always put it on a tender because I never know when I’ll get out riding again.
Doing this masked the fact that it wasn’t charging.
Turned out my regulator was bad then my stator to regulator plug disintegrated. Resulting in me having to install a new stator and new regulator.
If you get it running again put a voltage meter across the battery terminals to see what the reading is. If around 12 volts or less you have a charging system problem. Not sure what the spec should be but generally 13.2-14.5 is acceptable and your problem would be something else. My first check would be the ground wire making sure it was clean and tight on the frame stud.
oh edit to say I voted “yea” as I already did. Sold my 1998 FXDWG and got a 2010 FLHX!
Stiggy (08-17-2022)
Checked load today and it was stay at 12.3 so I am to replace the regulator
srose3388
08-01-2021 05:09 PM
