ACR Disable
It’s a shame you didn’t mention you had a FP3 in your original post. You would have gotten that answer in about 3 seconds like you did with the PV suggestion. Glad you put 2&2 together and figured it out.
Also, there are a lot of smart people here (and an equal number of fools, sadly) so when you present an issue, providing as much info as possible helps with the diagnosis. Not being critical, without experience its hard to know what is related to what, but just saying.
Lastly, were spokes standard on the '19's? I had the same bike in 2015 and they came with the same mags as my LRS, only black and silver instead of baby poop brown...
Good luck.
I've done quite a bit of the easier service work on earlier bikes( clutch adjustment, belt tension, etc. . Most of them pretty new so I didn't have to check compression. This Dyna I bought for a reasonable price but the owner was young and did not understand enough about bike so I want to check everything. Compression test went as follows, ACR's Off, Bike warm, Air Filter Out, Both spark plugs out, install gauge, Wide open throttle, turn over until pressure stops building. Result was 210 PSI front and back. Strong compression.
This Dyna low rider is a 2017. When the 1st owner bought it new he said it came with forward controls and laced wheels. I'm not sure if the dealer did this before putting on the floor or came from factory like that.
I plan on leaning on group for help as other than the Harley Dealer there are no independent mechanic shops within 50 miles. I may install a cam next so that's gonna generate some questions LOL. Fyi, I really like this Dyna and I have had many bikes. Harley's I have had. 1997 Dyna Wide Glide, 2010 Road King, 2017 Street Glide Special, and a 2019 Road Glide Special.
Yeah I meant 17. 19's are softails...
Someone changed stuff. The 2017 Low Rider came with "further forward" mids - basically mids that are about an inch and a half further forward from the standard mids. Really nice. Seems like someone was looking for a classic Harley look. Feet out, spokes, etc. Not my thing, but to each it own.
Talk to the boys over at @fuelmoto - they have some of the best support in the industry. They can recommend a cam and have a crap ton of how to videos on their site. Not sure they deal in the FP tunes, but if you get a power vision, you a get lifetime of some of the best tunes tailored to your build. A couple auto tune runs dials them in nicely...
Good luck with it.
Good luck with it.
Curated Content Editor
12-22-2020 07:18 PM
