99 dyna wont stay running
Hey everyone im having troubles with my 99 dyna fxds convertible with the 88ci . A little while ago on my ride home bike was running fine and came to stop at the lights, bike died on me while idling in neutral, started up fine and as i was taking off it felt like i had no power, got it home and then it wouldn’t start. Ended up taking it to a shop but no luck on getting it to run again without dying after firing up. We switched out the coil pack, plugs, cleaned the carb, and new crank sensor, but still wont stay running once it turns over. There is good compression, fuel is being sent and spark is good also. We are at wits end with it and cant figure it out! Please if anyone has some more ideas or needs more information to help it’s greatly appreciated as it my only mode of transportation right now
I know you say fuel is being sent but is it enough? I had a 1998 and my gas tank liner peeled off and would clog the petcock filter. Sounds like the same thing your experiencing, would stall, restart and stall again. Also check your battery ground cable at the battery and the frame. Even if tight, take it off and clean the mounting points.
Sorry we did do the crank sensor not the cam
James Carlson
04-29-2021 09:05 AM
WOS Bishop
08-24-2011 06:51 PM
