Does anyone have whats done at each Service Interval
RE: Does anyone have whats done at each Service Interval
Yep...four hours. They said they had to charge me what the book called for. And that didn't even include changing oil! It was also quite a coincidence that my inner primary bearing went out a mere 200 miles after their "service"...but I don't suppose they could have done anything to cause that huh? I took it to a different dealer for the bearing repair...they did it in one day! I thought I was back on the road, until I noticed oil pouring on the ground from the drain plug area. I checked the plug...it seemed loose, so I tightned it...still leaking. Then I read here that there isn't supposed to be much torque on the drain plug. Jeez, you'd think if they went to all of the trouble with the bearing, that they would make sure there weren't any leaks. It doesn't seem as though they even road tested it! I suppose I'll have to take it back...I'll be noting the odometer reading when I leave it there.
If I can do it myself, I will. If not, it sure as hell aint going to a HD shop. I have a local shop that I actually trust and their prices are about half what HD charges. Oh yeah and they don't charge by the magic HD "book". If something takes an hour, you get charged for an hour. I guess what I'm saying is check out independent shops if you don't want to or can't do it yourself.
