how to remove & cut baffles
I have some V&H short shots and I've heard the baffles can be cut to give it a deeper sound + reduce "popping" during de-celeration.
I don't want to pay a mechanic ANOTHER 2 to 3 hundred dollars to do it. Can I get some help on how to remove them and where and how to cut them?
Thanks
Thanks
should take about 40 minutes including cut time... check out the bike when it's cold. just a few bolts that hold the pipes on... so easy to remember.
to speed up the baffle process, take the pipes/heatshields off and then drill a hole in the heat shield where the baffle bolt is. then you can put the pipes back on and get to the baffles with no problem.
