frustration
frustration
Have an 06 Superglide that is driving me nuts. The front end seems to have a clunk to it when I go over any bumps. Also, when I decel or brake the engine by down shifting, I can feel a shudder through the handle bars.
Had it in at 1000 mile check up and asked them to look into it, and I just dropped it off again for the same thing. They said they checked the steering head bearing and all the adjustments were correct. Check all the front end bolts and everything was tight, I don't get it and I have a feeling, they don't either.
Any thoughts??????
Any thoughts??????
RE: frustration
The 'clunk' is pretty common, I have some clunk in my '07 SG. I hear you can add 1/2 ounce fork oil ,or change to heavier fork oil. As for decel shudder, is it really bad, or just vibration?..Harleys' (Dynas) do vibrate a lot compare to the foreign models..it takes a little getting used to..good luck.
[IMG]local://upfiles/38236/25872E373E834262993EE960675C1829.jpg[/IMG]
RE: frustration
I rode a loaner from the dealer that had that same issue (clunk when applying the brakes) the other day.. it was an FLH design though. It sounded as if it was comming from the forks and not the brakes. I think it was probably just low on fork oil.. as it tended to "dive" heavily more that what a bike really should. I have also heard that a heavier grade type of fork oil is sometimes a "fix" for this.
RE: frustration
When I had the injectors replaced on my 06 St Bob and the techs replaced the fuel tank, they swapped the front and rear mounting bolts. The rear bolt is just a little longer than the front and will bottom out on the acorn nut before securing the tank. This allowed the tank to "clunk" on bumps. Swapping the bolts cured that. If you've had your tank off for some reason, I'd check the the bolts.
RE: frustration
Slider, I have the same problem on my 06 Bob. The clunk I think can be fixed with heavier fork oil. As far as the shudder on decel & braking, this one has me puzzled. I looked at the front rotor, but nothing. I'm going to go through the front motr mount & go through the alignment process. I had the stealer look at the motor mount & said the it was o.k. & that type of vibe is normal. I believe otherwise.
