battery brand
02-21-2022 | 11:17 PM
6th Gear
battery brand
im wanting a new battery but im not sure which would be best I have the fxdx with a 131ci engine any recommendations ?
02-22-2022 | 06:32 AM
I've had more reliability with Interstate than any other...
02-22-2022 | 06:51 AM
Have had very good luck with Batterymart.com big crank batteries.
rk classic.
02-22-2022 | 11:44 AM
My Yuasa GYZ series battery has lasted me longer than anything else. Going on 5 years and still strong, but I might change it out just in case.
02-22-2022 | 05:05 PM
I went with Duracell from Batteries Plus.
02-22-2022 | 06:08 PM
+1 on Big Crank Batteries.
02-22-2022 | 07:05 PM
FWIW, those Big Crank batteries (along with many others) are made by East Penn Manufacturing who also make the HD and their own "Deka" batteries
02-22-2022 | 08:22 PM
Quote:
Originally Posted by
470004
same here, installed a few years ago and doing well.
02-22-2022 | 08:39 PM
Besides brand, look for cranking amps, especially for big motors. The same size battery can range from 280 CCA to over 500 CCA
02-22-2022 | 11:30 PM
Go LI, or plan on replacing the battery every year. I had a high compression 116 that blew about 3 starter clutches, 3 ring gears, and blew up one starter with good AGM batteries. Also have a 131 FXR that has blown fewer parts. LI bat fixed the issue.
