battery brand
Old 02-23-2022 | 12:21 AM
madmuthertrucker's Avatar
madmuthertrucker
I have been having good look with Deka batteries. I have one in the car and the bike.
Old 02-23-2022 | 01:13 AM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by DannyO702
im wanting a new battery but im not sure which would be best I have the fxdx with a 131ci engine any recommendations ?
NOCO Lithium NLP20, Group 20, 600A Lithium Powersport Battery
https://no.co/nlp20
Old 02-23-2022 | 02:13 AM
DannyO702's Avatar
DannyO702
6th Gear
yea that's what im looking to get is cca but also quality
Old 02-23-2022 | 06:22 AM
98hotrodfatboy's Avatar
98hotrodfatboy
https://no.co/nlp20
What year is your bike?
Cause if your gonna go with a battery like that then you better make sure the starter cable can handle the load...
Max Headflow (02-23-2022)
Old 02-23-2022 | 08:56 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by GearheadMike
Besides brand, look for cranking amps, especially for big motors. The same size battery can range from 280 CCA to over 500 CCA
While looking at the specs is good, you won't find a ADM battery that fits a Dyna that has 500 cca unless they are lying / cheating on the spec. AGM is OK for baggers with larger motors as the battery is 30-40% larger.
As far as AGM Batteries go, Deka is the same as the HD battery. Yuasa GYZ batteries are a little bit better due to them figuring out how to get about 10% more lead into the battery. Batteries with bloated specs are typically one of these 2 if they claim to be made in the US.
dfixit1 (10-13-2022)
Old 02-23-2022 | 09:06 AM
rol427's Avatar
rol427
"Go LI, or plan on replacing the battery every year. I had a high compression 116 that blew about 3 starter clutches, 3 ring gears, and blew up one starter with good AGM batteries. Also have a 131 FXR that has blown fewer parts. LI bat fixed the issue."
Max,
Are you concerned with the Li batteries occasional fires?
Old 02-23-2022 | 09:22 AM
98hotrodfatboy
Max,
That would make me think...... Uh yeah...
My question would be though,
Would one need to make changes to the regulator..? Don't LI batteries charge at a different rate than an AGM or Lead Acid??
Old 02-23-2022 | 09:29 AM
Max Headflow
Max,
As I understand it, early Shorai batteries were bursting into flames.. I know of one shop that had a customers bike burn a battery. IIRC it was about 10-12 years ago. I currently run a Shorai in my 116 (soon to be a 107). It's about 4 years old, and still has plenty of cranking amps. I would have been through 2 agm batteries and either a ring gear or starter clutch in the same time.
I would imagine bikes that burn up batteries have charging issue or possibly simply loose battery terminals.
Old 02-23-2022 | 09:44 AM
Max Headflow
The LI batteries can typically be charged at rates higher than Lead batteries. The big issue is over charging. That can set them off.
Old 02-23-2022 | 10:19 AM
TriGeezer's Avatar
TriGeezer
Any of the top brand names are good. The Harley ORM battery is good. I recently put a Yuasa in mine. Don’t get wrapped up in CCA specs. The starter motor is a 1.5kw motor. So, even if the voltage drops to 10 volts during starting , the most the starter will draw is 150Amps. I’m more concerned with Ah rating. That’s the capacity of the battery.
madmuthertrucker (02-23-2022)
Quick Reply: battery brand
