??? Tires again
??? Tires again
I have done searches on rear tires for the Street Bob, and most are old. Meaning have not found posts on the GT502 tire and or other tires as a replacement in brand and size. What is the mileage and ride feel you have gotten? And any problems you may have with what tire you went with.
Thanks
RwP
RE: ??? Tires again
O5 Wide Glide. I got 12k out of stock front and rear Dunlops. New Elite 3's ride real nice and don't track the cracks in the road or tar snakes. So far I haven't hit any rain but that's the only questionable area. I may try Metzler 880'snext. Good luck hunting for tires!
RE: ??? Tires again
If the tries does not get more than 8000 or 9000 out of them is that an upgrade? I’m looking for a replacement tire that I can get better mileage from. For me stock size is ok, I just have not found one that people say wears better than stock, from what I have read, the gt502 will wear faster.
Rick
Rick
ORIGINAL: Frank Castle
I got 6400 out of my original 160/70 see my post and the thread with it on the GT502 titeled as "180 wide tire issue solved" if you want to upgrade to that tire for your bike
RE: ??? Tires again
As far as an "ugrade"... its not necessarily a performance upgrade or superior to any other tire that I am aware of in longevity. I have also heard that the GT502 wears quicker too,although I do like the ride the GT 502 is giving me now vs. my old 160/70, it tracks straight as a string. I cant tell how its going to wear as it is my first tire of this type /size and variety. I like the look, although it does seem a bit softer than the old tire. If you are looking strictly for longevity I would suggest a Metzler I have heard nothing but good about them and their abilities.. Its just that they dont make a "wide tire" of the same variety as Dunlop. They probably make a 170 or a good 160 that will fit your needs.
RE: ??? Tires again
Check the speed & load rating for your tire. Dunlops run a softer rubber for grip and a higher speed rating for the new bikes. Your can go with the goldwing tires size that are not made for your bike. They do last longer with a harder rubber tire and less grip. They have a H rated and not V rated tire. It is your choice.
