decel popping / blue flames
RE: decel popping / blue flames
I could be WRONG??, but will not admit it if I am.
Looks like you have "Longshots" on your bike. Articles I have read in the past few years say they will contibute to said problem (loading up fuel in the exhaust).
That really is a beautifully done bike.
Where did you get the front fender, if I might ask??
I also think you should go for BOTM.
DougJ
DougJ
ORIGINAL: cardboard
Hummm come tell that to my buddy that has the Big shot longs on his 96 wide glide, it don't pop or have blue flames coming out the build engine with CRane heads and cams in it.
DougJ
Cool man, blue flames is from unburnt gas. Its according to how the unburn't gas got there. I'd rather have a motor running rich than lean. But too rich can cause Carbon build up and cause the bike to flood out some. It won't burn a hole in no piston and can be fixed oh.
We all learning oh. Good to learn. I'm still learning. At my age I learn and when I learn somemore, I forgit what it was I learned the 1st time too. Drink !
Informative post. Thanks. I just bought an 02 Dyna Low Rider and it was popping a lot at lower altitudes - got it in Milwaukee. As soon as I started gaining altitude, it started sounding better. Much better now that I'm back in Billings (3,000 ft). Gas mileage seemed to get a little better too, was barely 40 mpg driving the speed limits and not hot rodding. Will have to monitor that for a while, but it points to the thought that it might be running a little rich. Bike had SE-2 pipes, SE filter and was supposedly rejetted by the first owner.
ORIGINAL: WildBill76
Cool Bike. Too rich can also dilute your oil and speed up engine wear. It is a delicate balance.
But I got a good mechanic. Don't let my bike git like that.
My mechaniceven says don't you ever check the air in yer tires. Nah that's what I got you for.
Well, I guess I'm gonna have to disagree with what others have told you. First, you bike is OK - popping on deceleration is fairly normal - constant backfiring is not - but popping on decelis something that a fair number of bikes do - maybe not all, but a fair number. Some people like it - some don't. Some people spend a lot of time, money, worryand energytrying and to get rid of it. Doesn't bother me and all my bikes over the years have done it to some extent,some more than others. But, in general,I prefer to ride rather than sweat the small stuff and I actually enjoy the popping.
I'd guess you are running somewhat lean as the typical stage one download with the free flowing pipes and air filter generally result in that condition.
As to the flames - The blue flames you saw are the result of un-burnt fuel igniting. You blip the throttle and you dump a large amount of fuel into the cylinders -fuelis entering the cylinders at the same timeexhaust fumes are being sucked/pushed outof the cylinders. In this process some of the incoming fuel is sucked out - especially true when blipping the throttle as itdumps a fair amount of fuel into the cylinders quickly.Your exhaust gets hot enough to ignite the un-burnt fuel and you get blue flames at the tips where there is more oxygen to help burn it.JMHO
My guess is that the majority of bikesdo the same thing when blipping the throttle but most of us never sit in a somewhat dark place or at night blipping our throttles and looking at the exhaust to see what happens. Might be something to try out tonight.
Read the origional post. He states he has a "decel" popping. That would be when he rolls "off" the throttle.Popping at that time would be caused by a rich mix, as a lean mix would not provide fuel to ignite in the exhaust.
If he had said accel popping or backfiring I'd be inclinded to aggree with you. But if he's holding open throttle for more than a secondor two then letting off, the over rich accel dump has had time to blow out the back.
