Big Al risers vs. ??? - also, which bars?
Hello all,
I have decided to move over to some 9 - 10" risers and MX style bars for my 2010 Street Bob. Currently have wide 12" ape hangers from KST, but I need to narrow the bike's overall footprint for a few reasons... I have also been wanting to try some of the Big Al style risers and an MX bar for a while.
In any case, I really like the thicker profile of the Big Al risers, but I've seen a few competitors offering this style now as well. Death Metal Racing has the Destroyers, LA Choppers has a version, and even amazon.com has the Goldfire brand available. Looking specifically at the 10" risers with pullback.
Does anyone have experience with more than one brand of these style risers? Pros, cons, etc.?
While I really like the Big Al style, I also like the Forbidden Motorcycles gold bars and black risers combo... Any feedback on these?
Also, I am not sure which bars to pair up with the riser. I'd like to stick with 1" diameter due to ease of the install and the fact that they'll fit my current controls, etc. Any recommendations on a brand, width, etc.?
Hello all,
I would stay away from the Amazon and eBay specials. My experience with the Goldfire risers wasn’t good.
lespaul6 (10-27-2021)
Hardcase Performance makes really nice risers, lots of color options, drilled for wires. Very spendy though. TC Bros also makes a really nice modular riser available w/pullback. Most of those style risers come with a 1” clamping area for standard bars or 1 1/8” for mx style bars. If you do fo with a 1 1/8” bar and riser the bars will be tapered so you won’t have to change your controls. So don’t let that worry you.
I looked at the Hardcase risers, but I agree that they are very very pricey. Leaning heavily toward the Forbidden Motorcycles risers right now. Not sure how I feel about the TC Bros modular, as I think I want the riser and lower clamp to be 100% solid... also, they only have black and raw aluminum option... so I don't see the advantage over the FM risers right now.
Thank you for feedback. Would you explain the issue you had with the Goldfire risers?
I didn’t know forbidden made a pullback riser. Interesting.
The 1” clamp area wasn’t a true 1”, it was just a bit too big. I’m assuming since they’re Chinese however they made the hole for the bars they didn’t have a 1” tool so they probably used a 25.5mm and hoped that the finish coating would make up the difference. Well it did, sort of but it still wasn’t right. I then used a really soft cork wheel to remove the coating and made shims for between the bar and risers. After all this I still couldn’t get the risers to clamp up squarely. No matter what I did the bars were always tweaked one way or another. Not to mention having metric hardware, which isn’t a HUGE deal just another wrench you have to bring along that only serves 1 purpose.
Forbidden actually doesn't make pullback risers, so they would be a compromise... Essentially, I am deciding if the pullback is worth the extra ~$200-400 for the higher end options... I am going to try a buddy's FXDX with straight 11" FM risers tonight, so that will help with the decision a bit.
If your budget is there, Kraus risers, either straight or pull back with Big Al's low low bar. It will take custom machine work to get them to mate together properly, but it is worth it. No buzzing and mirrors are functional. Only 28" wide. Great for lane splitting.
https://www.krausmotorco.com/collections/risers
https://www.bigalscycles.com/product...-low-bend-bars
Dave
Dave
Hmm, if I'm spending someone else's money then some of the set ups I'd run.
Death Metal Racing pullbacks in 10" with Thrashin Hi-Bend's
Bare Knuckle Modular risers. These are bitchin because you can tailor the height and pullback super easily. Also with Thrashin hi bends.
Since I'm cheap however I normally run Biltwell Murdoch risers in 10" straight or pullback and Biltwell High Trackers.
Currently I run Thrashin hi's on 9.5" Drag Specialties pullbacks and this by far is the most comfortable setup I've ridden. Not the coolest or most expensive but function over form this time around.
Boosted Brad (DMR) makes some really cool stuff as well. I have his boards and mini bear trap pass pegs along with his hydraulic clutch cover. If I didn't have my current risers I would have gone with his. He's a solid dude as well.
shiftace (10-25-2021)
