Longer Rear Brake Rod for Dyna
Hi, I installed Shred Moto pegs for my '16 FXDLS, and need a longer rear brake rod to raise the foot brake lever. Right now it is at max level with the stock brake rod, but it needs to be higher. Are there any longer brake rod 1"-1.5" longer rod for '16 Dyna?
Thanks for your help,
https://www.mcmaster.com/studs/
https://www.mcmaster.com/nuts/coupling-nuts/
If all else fails, go buy a 5/8" mild steel rod from a big box store and make one. I had to do that for a forward control brake rod that interfered with an exhaust pipe that was marketed to work with forwards. Wasn't hard to do at all if you have access to a drill, the correct tap, a dremel, and a torch for any bends you might need to do.
Per BlueBob's direction, I ordered following from McMaster.
316 Stainless Steel Coupling Nut
Super-Corrosion-Resistant, 5/16"-24 Thread Size
90104A108 1
each 8.70
each $8.70 2 18-8 Stainless Steel Coupling Nut
Extra-Long, 5/16"-24 Thread Size, 3" Long
90268A417 1
each 39.94
each $39.94 3 Super-Corrosion-Resistant 316 Stainless Steel Threaded Rod
5/16"-24 Thread Size, 2" Long
90575A283 1
pack of 5 5.85
pack $5.85 4 Super-Corrosion-Resistant 316 Stainless Steel Threaded Rod
90575A284 1
pack of 5 7.22
pack $7.22 5 Super-Corrosion-Resistant 316 Stainless Steel Threaded Rod
5/16"-24 Thread Size, 4" Long
90575A285 1
pack of 1 1.65
pack $1.65 6 316 Stainless Steel Thin Hex Nut
94805A213
I bought various sizes, just in-case. hope this will extend my stock rod.
Thank you Blue Bob. Nice bike btw. How did you install radial calipers for that Ness rotor?
90104A108 1
each 8.70
90268A417 1
each 39.94
90575A283 1
pack of 5 5.85
90575A284 1
pack of 5 7.22
90575A285 1
pack of 1 1.65
94805A213
90104A108 1
each 8.70
90268A417 1
each 39.94
90575A283 1
pack of 5 5.85
90575A284 1
pack of 5 7.22
90575A285 1
pack of 1 1.65
94805A213
90104A108 1
each 8.70
90268A417 1
each 39.94
90575A283 1
pack of 5 5.85
90575A284 1
pack of 5 7.22
90575A285 1
pack of 1 1.65
94805A213
You can easily return the parts to McMaster you don't need.
Caliper mount pretty much a one off I designed.
Regardless, glad the OP got what he needed.
I will have to respectfully disagree that the "correct" way involves a lathe and mill. Pictured below, I don't see why you would use a mill or a lathe to fab this part (unless you want to turn it before bending or cut the end threads with a lathe). Once sanded and painted, it is indistinguishable from the OEM rod, except for the modified geometry. For an extension piece or a new straight rod, sure, go ahead that makes perfect sense.
Thank you for your input as well. Although it seems easy enough to buy a longer 5/8" dia rod and thread them as you have(probably cheaper too), I just followed the simplest solution to extend stock rod with coupling and a threaded rod method. Your method will probably help others who might want alternate solution. Again, I appreciate your help.
