Carb flooded. Low speed jet blocked.
Gents. I have a stock 2000 Dyna Wide Glide, carbureted. About a month ago, I was rolling down the highway at about 55MPH. I rolled on the throttle, and the bike sputtered as if out of gas (lots in the tank). Even a little throttle would cause sputtering. Constant speed was fine. When I came to a stop, the bike died, and fuel gushed out of the air cleaner housing. I opened it up, and more fuel drained out of the carb throat. I had the bike towed home, and serviced the carb. All seemed normal, except the low speed jet was completely blocked. I cleaned it up, and the bike is running fine now. Does it make sense that the blocked low speed jet could have caused this? The only thing that I can think is that with the low speed jet blocked, excessive fuel was being sucked through the main jet, thus causing a flooding condition. Your thoughts?
I would remove the carb, then the float bowl. Look for any trash/contaminants in the bowl and flush it out with carb cleaner. Remove the slow jet clean it with a small brush and carb cleaner. Remove the float from the body, then the float valve. It's possible the float valve wasn't closing all the way during operation and just letting the fuel to continually flow into the bowl. Clean the float valve seat for any varnish that may have built up. Reassemble. Go to a hardware store and replace the float bowl screws with allen head screws. I think a 6x12 mm screw or 4x12 mm screw( take one with you) will make it easier in the future for removal. Run a couple of tanks mixed with Sea Foam at recommended dosage to clean the internal passages in the carb.
seniorsuperglideE8 (09-13-2021)
That said, all that extra gas everywhere sounds a lot more like a stuck float valve than anything else.
