What’s that on my exhaust?
Old 09-01-2021 | 04:55 AM
HDkazHD's Avatar
HDkazHD
Default Active Exhaust Valve
How do I check if this is working?
This is the fully opened position?
Old 09-01-2021 | 05:48 AM
IronAss's Avatar
IronAss
I have no clue what that is but would be curious to know.
Old 09-01-2021 | 05:53 AM
TracerBullet's Avatar
TracerBullet
No idea. Never seen anything like it before
Old 09-01-2021 | 05:57 AM
Jackie Paper's Avatar
Jackie Paper
Export model. Sound? Read your owners manual and add a picture for us and use instructions. Not on ours. Think it is part of a cut out to share or not share both mufflers for sound control. Why you have two sizes there. Be sure it's not for fuel available for catalyst muffler if your bike has that. If so, you could screw something up using it improperly.
And.
Welcome from Hampton Roads Virginia USA!
Just in case you have not done both of these two important items!
Be sure to add an Avatar of your favorite shot in the USER set up for the small picture others will see in the top left corner of your post with your USER name.
And most importantly a Signature Line in your USER set up for your bike model, year, and all the letters that Harley recognizes it with that others see at the bottom.
This enables others to know your exact model if you ever ask a question or another member interested in it may ask you a question about it.
​​Your all set.... Enjoy the ride! ______________
Old 09-01-2021 | 06:24 AM
joe40x's Avatar
joe40x
Only on exported models.
Old 09-01-2021 | 09:16 AM
HDkazHD's Avatar
HDkazHD
how to use or test it?
I don’t have any manuals as I bought it used.
Old 09-01-2021 | 12:03 PM
Jackie Paper
Go to the Harley.com mothershp site. Search user manual. Think they are going to want your vin number. You will be able to create a user and have access to it free on line. They charge for a paper copy
Old 09-01-2021 | 03:44 PM
bicio's Avatar
bicio
That valve is supposed to be closed at idle and then open once throttle is given. On my bike it was already deactivated by factory, so yours should be the same.
check is simple: according to your picture the valve is already open. Start the bike and check if I’d does not move both at idle than with throttle (2000-2500 rpm). If you have a POWERVISION you can also check if “active exhaust” is deactivated or not.
That valve is completely useless, so leave it deactivated if is already on that setup.
In case you decide to change the headers in the future, a dedicated sim connector will be needed in order to avoid error codes due to the valve motor removal.
Old 09-01-2021 | 03:49 PM
theheder's Avatar
theheder
Never heard of such but interesting feature
Old 09-02-2021 | 05:58 PM
Dyna100's Avatar
Dyna100
My Z06 Corvette has a similar set up.
Quick Reply: What’s that on my exhaust?
