I think I'm having problems!
Before I start my bike the dealer said I should wait till the little yellow circle type light goes out.... OK sounds good so I do this every time I start it... Now I just noticed that the little yellow light comes on sometimes when at idle then when I throttle up it goes off.... Now today I went for a small ride and I stopped at the store shut it off and when I press the kill switch to on and the injectors kick on and make that little hum.... I noticed my mile numbers said (diag) then some number then diag again and it never went back to the miles.... I turned the switch off and then the key switch off and re tried it again.... this time it didn't do it and it hasn't did it again sense. Should I be worried? Should I have it checked out? What do you guys think??
All help is appreciated!!
Donnie
Donnie
RE: I think I'm having problems!
if you go to the diy - engine diagnostics section of this forum, the 1st page will show you how to retrieve the code, and what it means.
............when you say it was acting crazy after the rain , sounds like it might have happened there.
as said above, can go to the dealer anyway....
Inspector 12
07-16-2013 06:54 AM
