Dyna wheelie issue
Old 10-13-2020 | 08:16 AM
Dudepants's Avatar
Dudepants
What about a Lectron carb? Think that'd help with starvation?
  #32
Old 10-13-2020 | 09:15 AM
Bob_fxdb's Avatar
Bob_fxdb
Most stunters use mikuni and some cv, haven’t heard or seen anybody using lectron yet. I reckon it’s best to use something that is known and used by them big boys.
fyi, I’m riding a newer dyna with efi and now consider switching to the old frame, either with carb or efi. Haven’t decided yet. I have only tried stock and mikuni from friends bike and been doing research about this subject. Things that I have said is not based on my experience but by others and my own research.
  #33
Old 10-14-2020 | 09:50 AM
Bubba Zanetti's Avatar
Bubba Zanetti
My question is how do you avoid banging up the rear fender or breaking the tail light when at 12 o'clock? Is the fender bobbed off?
  #34
Old 10-14-2020 | 05:40 PM
REW13's Avatar
REW13
Originally Posted by Bob_fxdb
no problem with 39mm. Stock springs works, but will prob not last for so long with hard landings. Seems like he knows his stuff so those springs prob upgraded
Popped one wheelie not by choice, but I thought I bent both tubes and my front end on came about a foot off the ground..
They (39mm) should be fine in theory, because of motocross but those bikes definitely do not weigh near as much as a Harley.. Half of the weight.
  #35
Old 10-14-2020 | 06:00 PM
Dan89FLSTC's Avatar
Dan89FLSTC
To be more specific, the stock cuts your fuel because of vapor lock. Get a mikuni or cv carb. I don’t think it’s a way around without modding the carb?
Actually, it is fuel starvation, because the fuel pick up in the carb is above the fuel level in the bowl.
Vapor lock is when fuel boils in the fuel line or fuel bowl, creating pressure that prevents fuel from flowing into the carb.
  #36
Old 10-14-2020 | 06:31 PM
Bob_fxdb's Avatar
Bob_fxdb
I see. Some of the OG wheelie dudes told me so I just kept saying that. Anyways, both term explain the fuel issue and stock carb still trash
Yeah, I understand what you mean but 39mm tubes are not that easy to bend on the direction the fork is hitting the ground. Stiffer springs if you into the wheelie stuff, or in general if you want a better ride overall. That’s another topic. Haven’t seen or heard stunters bent their tubes on hard landings. I had a sportster with 39mm when I was learning to wheelie harleys, and it went through a lot of hard landings. Had progressive springs in them with thick fork oil. No problem. It’s just in your head.
  #37
Old 10-14-2020 | 06:43 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Only trash when doing wheelies...
  #38
Old 10-14-2020 | 06:56 PM
Bob_fxdb's Avatar
Bob_fxdb
Haha nah, you for sure gonna feel the difference between stock and aftermarket. Stock works for sure, but not as good as they should. But by any means, I don’t see why one should upgrade it if you don’t have complaints or gonna do some works one the engine.
  #39
Old 10-14-2020 | 09:05 PM
Suede Blue Man's Avatar
Suede Blue Man
And never let anyone tell you it's too early in the morning to do wheelies, it's gotta be 12 O'clock somewhere
The following 2 users liked this post by Suede Blue Man:
DynaKid94 (10-15-2020), rustbelt shanks (11-12-2020)
  #40
Old 10-14-2020 | 09:47 PM
REW13's Avatar
REW13
And it's a bad picture too...
Guess it's because I bent and broke so many BMX bikes when I was younger..
I did bend an Enduro's forks from wheelies and jumping.
Quick Reply: Dyna wheelie issue
