01 FXDL makeover.
Thanks Chad, appreciate the props!! Yeah I’ve ran em all but always come back to my first love. Thunderheaders always have a spot in my heart.
Hey shift. How do the bagger calipers stop? Good? So so...
Also in case I missed it? Did you replace the tensioners?
When I got my bike it had low miles too for the age, and I had the tensioners checked. They were fine at the time but 2 hundred miles later they came apart! Hate to see it happen to anyone else....
But now all is good... Gearz, light cam and carb and bike runs like a charm.....
BTW even if you upgrade your rear shocks to the drag specialties it's a major improvement
shiftace (03-11-2020)
I love DX shocks, and honestly I’ve never out ridden these shocks or wished for more, since they do everything I ask. Plus I like stock stuff that looks and works as good as most aftermarket stuff. Now, money no object I’d do Ohlins mostly because they’re pretty easily serviceable and offer tons of adjustment just not budget friendly.
“Planning” on a whole motor/trans/primary upgrade next winter so stashing money away already.
Question for you, when you installed your Thunderheader bracket how did you handle the stud that I have circled in red? When I installed mine, if I left the stud in the case the fixed nut pushed the bracket out and if I tried to put the stud through the bracket it was too short. I ended up grinding down the fixed nut on it so it fits inside the hole in the bracket, then used the nut that held the OEM bracket on.
