A Little More Wiring Help Please...
Old 02-10-2020, 01:08 PM
Bob_fxdb's Avatar
Bob_fxdb
Bob_fxdb is offline
Originally Posted by snake_eyes
And the award for most unhelpful reply goes to ^^^^
If you read my post you'd see I'm not asking 'cause I tore **** up and don't know what it is, I am asking because they were already unplugged and I want to know what they are. Sheesh....
Thank you
Btw, been noticing you been asking for help a lot lately. Its nothing wrong with it and Im glad people can help each other. Just a crazy idea, what about investing in a manual?
https://lmgtfy.com/?q=harley+davidso...ual+2017&iie=1
Old 02-10-2020, 02:38 PM
snake_eyes's Avatar
snake_eyes
snake_eyes is online now
Received 1,246 Likes on 730 Posts
Originally Posted by Bob_fxdb
Thank you
You're welcome.
I have a manual, use it all the time. Are you from Minnesota? 'Cause you rule at the passive-aggressive insult.
Old 02-10-2020, 02:50 PM
snake_eyes's Avatar
snake_eyes
Originally Posted by touchdown
I think they are open plugs maybe for heated grips. But if you just want to check turn them over and count the wires and colors male and female should be the same amount of wires and the same colors. Most of the time male wont fit into of the female if its not the same.
That was a good thought. I checked and FXDB's don't support plug and play heated grips, even dug into the installation instructions on a couple of pairs. Even though they are male and female they don't go together, wire count and color are different on either side. Can't be cruise because the bike is not fly by wire...maybe security system? I'll check that next...I mean is freezing cold here and I can't ride and I work at home so I have the time.
touchdown (02-10-2020)
Old 02-10-2020, 03:34 PM
joe40x's Avatar
joe40x
joe40x is offline
Top left dia.
Black, yellow and white are headlight colors, Aux/crash bar light hook up?
The other plug appears to be for the international single headlight...Hard to tell the colors from the pic.
https://serviceinfo.harley-davidson....271248c2!!10!8
Old 02-10-2020, 04:01 PM
snake_eyes's Avatar
snake_eyes
Originally Posted by joe40x
Top left dia.
Ran back outside and looked again to be sure, my eyes are getting old.
Female plug is Light Yellow/Yellow/Black
Male plug is Blue-Black/Blue-White/Blue-Yellow/Black
Old 02-10-2020, 04:10 PM
joe40x's Avatar
joe40x
joe40x is offline
Female is for the international headlight.
There is no lt yellow listed that I can find...probably white. That would make it the headlight.
3rd and first diagrams, upper left hand corner.
Old 02-10-2020, 04:11 PM
snake_eyes's Avatar
snake_eyes
Top left dia.
I'll be dammed, it is there. The bottom diagram in the upper left. That Blue-Black wire shows as HDI only. Do they wire all bikes for all destinations?
snake_eyes's Avatar
snake_eyes
You beat me to it.
Old 02-11-2020, 09:09 AM
Jay Guild's Avatar
Jay Guild
Jay Guild is offline
The main wiring harness is standard for multiple destinations. If you look at the throttle body there is also the international sensor connectors there with one or two that go nowhere as well.
Old 02-11-2020, 09:24 AM
snake_eyes's Avatar
snake_eyes
Yup, I noticed that. There is a plug right beside the throttle body on mine but at least it has a cap on it so it's clear that it's not used. Mine also has a retainer on it, you know the pushpin plastic-type? But it's pulled out and I can't find where it was secured to. Friggin dealers up here pull the battery tender connection loose from under the seat and route it out in the open by the coil since they need to plug them in so often on the showroom floor. Problem is some guerilla gets in there and pulls a ton of other plugs loose from their securing point.
JasonA1
EVO
30
02-17-2019 06:04 PM
woodguy75
Electrical/Lighting/Alarm
11-06-2018 08:36 PM
jqb12
04-28-2017 06:56 PM
Stag556
12-06-2011 08:38 PM
fishawk
01-13-2007 12:23 AM
Quick Reply: A Little More Wiring Help Please...
