Is anyone running a smaller front compensator sprocket?
I'm in the process of hot rodding my 02 Low Rider and was talking with a guy that used to build some bulletproof 95" motors and he advised me to run a smaller compensator sprocket like Screamin' Eagle used to offer. The one from the Screamin' Eagle catalog is obsolete now, but I figured out that the sprocket from the kit is a 21 tooth sprocket versus the stock 25 tooth. Has anyone done this? doesn't it really make much of a difference? I did some research and it does change the gearing quite a bit but I haven't heard many people going this route. If anyone has any input I'm all ears. Thanks in advance guys!
That would definitely be an amazing step up in torque, same reason why drag racers will used a 4.10:1 over a 3.55:1 rear end gear. I would imagine the RPM cruising down the highway will be greatly increased (if that matters to you) I have re-geared many trucks and cars and I can tell you the difference it made in those was absolutely substantial in power from low end to high end, it just makes the engine not have to work as hard to accelerate the bike. might be worth a shot if you don't mind gas mileage decreasing and over all top speed decreasing. just my $.02 ride safe!
Edit: nice looking bike BTW!
I'm no guru but on my 03 Dyna for my riding style the stock gearing was WAY too low. I basically didn't need 1st gear at all and that was with a stock 88" motor. When I installed a Baker OD6 tranny I went with a one tooth larger tranny pulley to raise the overall gearing. I love it now. With stock gearing I hit 5th gear at 45 mph. That don't leave much headroom with 70 mph speed limits.
I guess what I am getting at is do some serious RPM calculations vs. speed before you lower the gearing on that bike (at least from my experience). If it is just going to be a bar hopper then it may not matter to you, but if you want to actually go places on it lower than stock gearing on that bike might be a pain. Also keep in mind that the cam chain tensioners wear out quickly on those models. If you are increasing the rpms then it may increase wear.
Like I said I am not an expert but these are things that I have dealt with on my 03. My cam chain tensioners split in half at 39,000 miles and I do not ride hard at all.
Like said above, when you change one, it will effect the RPM's throughout the entire range. We offer a RPM ratio calculator on our site that you may want to play with to find what you are looking for.
https://bakerdrivetrain.com/pages/ca...e-rpm-vs-speed
Also, depending on what you are looking to accomplish, we do have 2 different ratios on our OD6 that might get you what you are looking for.
https://bakerdrivetrain.com/collecti...nt=19556554755
corliss@bakerdrivetrain.com (12-19-2019)
corliss@bakerdrivetrain.com (12-20-2019)
Got an email from Baker today.
They're having a "END OF YEAR" sale.
F5R is 10% off
F6R is 10% off
Armored Attitude Chain Adjuster is 10% off
Use Code: CHEERS10
DD7 is 15% off
Grudgebox Builder's Kit 15% off
DD6 is 15% off
OD6 is 15% off
Use Code: GEARS15
Comp sprocket is 20% off
Use Code BEERS20
Apparel is 25% off
Use code NewGear25
These are ONLINE ONLY offers.
Doesn't really say how long this offer is good, but probably until 2020, so get off your butt and order this stuff up.
No, I don't work for Baker, nor do I get one red cent from them in any way. (But, I DO have their compensator in my Dyna.)
F5R is 10% off
F6R is 10% off
Use Code: CHEERS10
DD7 is 15% off
DD6 is 15% off
OD6 is 15% off
Use Code: GEARS15
Use Code BEERS20
Apparel is 25% off
Use code NewGear25
corliss@bakerdrivetrain.com (12-21-2019)
Big Dave
23
05-18-2021 03:57 PM
