Speedometer not working, then loss of electrical power
The speedometer on my 2002 fxdwg quite working and the digital read out that says the mileage reads error. Then about 5 miles later my bike shut off like it's not getting electrical power. I have high beams but no low beam, no turn signal or tail light. The 2 turn signal indicator lights in my dash stay on though. If I hook my bike up to jump start it, it makes a clicking sound like the starter isn't getting enough power
David Hansen (12-10-2019)
Also, check the battery voltage with the ignition off. If it is under 11v or so once you turn it on it will drop .4v and start the clicking sound. It should be 12.6 or more I think.
Sounds like a loose ground or other loose wire like the John CC said, given the symptoms you describe. I just went through this little exercise. It was a cascading combination of wires working loose, 3 yr old battery, and bad voltage regulator. I have an '02 88 like you.
Good luck and let us know if that works!
yes the new battery is fully charged. Just took her out for about an hour.
Check the headlight bulb. When batteries crack they often loose their damping ability on the alternator. Alternators can put out a ton of voltage when there's no battery to damp them. If the low beam is burned out, look at the signal bulbs and flasher (if the bike has a flasher). If it's a newer bike with a turn signal control module, you could be looking at a new one.)
Also, look closely for signs of leaked electrolyte, even if it's a sealed battery. Clean anything up with a baking soda and water solution.
The following 2 users liked this post by John CC:
David Hansen (12-11-2019),
tygr1 (12-10-2019)
Received 4,482 Likes
I had a Sportster that did this. MOCO's power/ground are just long enough to go from battery to post or ground to ground. I started checking the terminals crimps and found the wires crimped in the terminal lugs had corroded to almost nothing, two strands were trying to carry the voltage. Check those swages/ crimped ends.
Ok. So I haven't fixed the turn signal yet. Yesterday though I was out for a ride and it did it again. Bike spuddered a few times then the battery died. The battery looked like it's been over charging. I replaced the battery this morning now the bike wont fire up. It turns over but no fire
