HD premium oil cooler kit
RE: HD premium oil cooler kit
ORIGINAL: DynaMoHum
Yep, more leaks if you don't glue the gasket to the adapter and torque the crap out of the new fiiter adapter fitting. I use 3m "77" on all my gaskets and it works great.
Just have the engine warm when you peel 'em off after they have been glued and you will have no problems.
Someone said a cooler only works with air moving. True to a point, the outside air will move and still disapate heat even when vehicle is not moving. Sure the heat radiating the temps from oil to air from cooler will heat surrounding air,but that air will always be cooler then the heat it is generating. So even while stopped it is still helping to radiate heat away. The amount however and overall effect may or may not be noticed.
ORIGINAL: gman
Really? You really think HD would add something free that they can sell to you later?
ORIGINAL: Punty
One thing I know that it does, it makes your wallet thinner
Bottom line if you reallyneeded it, they would have came with it.
Its all about preference. As for me I'd rather put it towards something else.
Good Luck
Good Luck
20% off
26151-07 Oil Cooler Dyna
http://chicagoharley.com/shop/advanced_search_result.php?keywords=26151-07&x=34&y=14
I was thinking about one also until a mechanic and
even a several old timers(HD owners) said I didn’t need one.
2015 Harley Davidson Street Bob Guy
08-13-2015 09:02 AM
