Front turn signal relocation solution
Since most everyone with the 49mm forks has issues relocating their turn signals, I thought I'd post the simple nice looking solution I applied to my 2007 Low Rider.
First I purchased the Kuryakyn 49mm turn signal mounts.
I then purchased a pair of stems from the Harley dealer for the turn signal relocation kit that comes from the manufacturer's kit for the Softtail, not the Dyna.
The dealer also had the torq bolts in stock to finish off what I needed to make the kit complete.
You will also have extra length of the wiring when you bring them down so I just looped the wire up and tied it together. Not perfect, but not bad either.
[IMG]local://upfiles/32289/675E67A012374F599A0A0B011767B557.jpg[/IMG]
[IMG]local://upfiles/32289/B55F30B7EFE94945B0CFD32E66F9EDCA.jpg[/IMG]
[IMG]local://upfiles/32289/D4AC3EFD79DE4217B864C38909EBFEB8.jpg[/IMG]
RE: Front turn signal relocation solution
If you swap them side to side you'll put the lens even with the front of the fork and they wont stick forward so much..
[IMG]local://upfiles/24219/462548511627401EADD56A43962400FE.jpg[/IMG]
[IMG]local://upfiles/24219/73AC851300A342E1834F7BDD82B2D53A.jpg[/IMG]
I went with the $5 mod and boy it looks awesome (I just wish I could figure out how to post pics here)
here is the link
https://www.hdforums.com/m_888979/mp.../tm.htm#888979
here is the link
