How to get rid of TSM
Old 08-24-2019 | 08:50 AM
Jacques's Avatar
Jacques
Default How to get rid of TSM
Hola amigos !
After bying a new battery, I noticed a tiny spark when connecting the battery neg cable to my dyna 2002 chassis.
So I wanted to measure the current drawn by the bike' s circuit,. Spark= current. My meter bridged between the neg from the battery to the bike chassis showed 25mA, with the ignition key to "off".
I started to investigate for finding out that removing the TSM solved the problem, though there is still .09mA remaining in the circuit, with TSM removed as well as all the fuses. My bike won't start without the TSM . Is there a way to get rid of the TSM by adding a small circuit for the bike to start ? I must add that I have modded the flashers to work without the TSM.
Thanks !
Colas
Old 08-24-2019 | 08:56 AM
JustDave13's Avatar
JustDave13
Veteran: Marine Corp
25ma? You know if you disconnect the battery your bike won't draw any current at all. 25ma is a drop in the bucket compared to most late model vehicles. If you're not going to ride daily hook a tender to it
Old 08-24-2019 | 09:04 AM
cggorman's Avatar
cggorman
Hmm... I removed my TSM several years ago and the bike starts and runs just fine. It's carbureted 99, tho. No idea what differs.
Old 08-24-2019 | 09:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The ground wire from the start relay goes directly to ground on pre 2001 models, but on 2001 and later the TSM/TSSM module controls the ground for the start relay.
To eliminate the TSM from this circuit, just ground the wire to a good ground point.
Best way would be to de pin the tan/green wire from the relay connector and zip tie it out of harms way.
Install a new pinned wire into the start relay connector, route the wire to ground.
This way your original wiring harness remains intact, in case someone decides to replace the TSM.
Zoomerduck (06-01-2024)
Old 08-24-2019 | 09:30 AM
JustDave13's Avatar
JustDave13
Why would you want to eliminate the TSM?
Old 08-24-2019 | 09:31 AM
Jacques's Avatar
Jacques
Cool ! I ll do the gnd wire mod and get back to you.
It is an hassle to get the battery discharged because of a faulty module. When I modded the flashers, it was beacause the left side had stooped working.
Thanks guys.
Colas
Old 08-24-2019 | 09:34 AM
Jacques's Avatar
Jacques
One more thing, what is a "tender" ?
Old 08-24-2019 | 09:40 AM
Uncle Larry's Avatar
Uncle Larry
http://www.batterytender.com/?CAWELA...SAAEgJtNfD_BwE
Old 08-24-2019 | 10:06 AM
cggorman's Avatar
cggorman
Similar to Jacques, I initially removed my TSM because one side quit (and failed the FSM testing procedure). A replacement at the time was over $100 (vs $10 for a generic flasher module) and I thought that was ridiculous so I worked around it. Eventually dropped in a Badlands module with more functions, then a Motogadget unit with even more. Full custom wire harness from bow to stern now...LOL!
Old 08-24-2019 | 10:14 AM
TriGeezer's Avatar
TriGeezer
I don’t understand why the TSM would draw current with the ignition off.
Quick Reply: How to get rid of TSM
