How to get rid of TSM
Old 08-24-2019 | 10:33 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Originally Posted by JustDave13
Why would you want to eliminate the TSM?
Why are you asking me? I just told the OP how to separate the start relay function from the TSM/TSSM.
The OP explained the reason in his original post.
Old 08-24-2019 | 11:04 AM
cggorman's Avatar
cggorman
Originally Posted by TriGeezer
I don’t understand why the TSM would draw current with the ignition off.
A TSM probably shouldn't, but a TSSM would need some power to keep the security system active.
Uncle Larry (08-24-2019)
Old 08-24-2019 | 04:13 PM
Jacques's Avatar
Jacques
I was mistaking myself between a battery tender and a tender battery..... ( love me tender, battery )
Seriously now, my TSM is in fact a TSSM. I had removed the siren last year. I build guitar tube amplifiers and when the switch is flipped off, there is no current , 0mA passing through the circuit. I cant understand the current path of my motorcycle if the key is at "off". Anyway, without the TSSM, only .09mA is drawn from the battery so it s not a big deal thpugh I dont understand why.
Cheers !
Old 08-24-2019 | 05:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
A TSSM is a Turn Signal/Security Module, it uses a small amount of power when the iginition switch is off to power the security system.
A security system that turned off when ignition was turned off wouldn`t make sense.
Now that we know you have a TSSM, keep in mind that module not only controls the ground circuit for the start relay, it also controls power to the ignition, by sending an enable signal to the ignition module...
Old 08-24-2019 | 05:46 PM
Jacques's Avatar
Jacques
Oh **** ! Then I ll have to buy a new TSSM ?
CAN'T I just feed the ignition module with reg 12 V ?
I
Old 08-24-2019 | 05:57 PM
Lambda's Avatar
Lambda
I
The ECM won't give you any spark or fuel if the TSSM is missing or is there but hasn't authenticated with a fob or by the code.
Old 08-24-2019 | 06:20 PM
Jacques's Avatar
Jacques
WTF !!!!
So I ll have to go to the dealer to get the new TSSM installed? There has to be a way for me to do it in my garage. You think my bike has got a ECM even if carbed ?
Old 08-24-2019 | 06:54 PM
John CC's Avatar
John CC
Why don't you just put the old one back? I don't think 25ma is excessive. Also, it may "go to sleep" after a few minutes and drop a lot lower.
Old 08-24-2019 | 07:05 PM
Jacques's Avatar
Jacques
Yep that s wat I will do...
.....and buy a love me temder battery temder
Btw the last Elvis Presley's Harley Davidson motorcycle went for sale.....my bank account was nearly empty...**** !
Jacques from Montreal ( where the roads are f....horrible ).
Old 08-24-2019 | 07:09 PM
Jacques's Avatar
Jacques
My tel too small I meant T E N D E R. Like Fender but with a T.
Hey Darling, bring me another beer !
And love me tender....
Thanks my friends...cheers !
Quick Reply: How to get rid of TSM
