Neutral Light Question
How is the neutral light triggered on pre-CANbus bikes, and is there any adjustment or fiddling possible? Mine was always super reliable and accurate. But since things have been back together after winter stuff, it's not behaving quite right. I'm able to find neutral without the light being illuminated, although it works (and lights up properly half the time). For example, I'll go up and down between first and second (my neutral isn't SUPER hard to find, but sometimes takes a couple of shots), and the light does flicker as I go through neutral. But when I find it, the light may or may not light up. The gauges and idiot light panel were apart, but everything up there is either plugged in or not plugged in. Fortunately, it hasn't lit up when I'm NOT in neutral...
