Engine not start in gear and pressed clutch
Hello,
my 2013 Dyna Wide Glide / 103 / starts the engine only on a neutral gear. In the user's manual it says that engine start on gear and press the lever clutch. The button on the lever works because it shows me on the display. Where can the malfunction?
https://www.hdforums.com/forum/dyna-...t-in-gear.html
Scoll down to Post #6. Check that and report back.
Dave
Dave
It's probably the clutch switch in the left switch housing, either not engaging completely, or not working properly. Stealership will want to charge a LOT to switch out the entire switchpak instead of just the clutch switch itself. You can get just the clutch switch itself online fairly cheap, but not sure how much of a PITA running the wire through would end up being, though you could just change it out if it's actually bad. Some have said that changing their primary oil also made a difference in how easy it is to shift into neutral, so that's something else to check on or think about.
