Anything 06 and up should bolt on with the right bracket. But anything older than I believe 2012, will need reducers for the o2 sensors as the older bikes used bigger 18mm ones.
I found a stock exhaust (2 into 1) from a 2016 Low Rider that I would like to put on my 2012 Dyna. I'm think it should bolt right on? No need to change sensors or special brackets?
Cant say 100%, but you will most likely need a bracket for that lowrider exhaust. This is the bracket for a lowrider, couldnt find an example for the superglide. But if you dont have this you will need it.
