Vance Hines Fuel Pak
Well after having installed the Stage 1 High Air Flow kit, Rush slip-ons (2" Baloney Cut), and the Harley factory re-map download forjust over a year nowI decided to try a Vance & Hines Fuel Pak.
Before adding the fuel pak I was getting about 36 MPG. Now with the fuel pak I got 42 MPG in the city. I can't wait to see what kind of milage I will get on the open highway. I might have to plan a road trip just to see.
RE: Vance Hines Fuel Pak
Could you share your mode settings, because mine gets an occasional loud pop?
I would appreciate it.
ORIGINAL: Matrix
No popping before andhad a little every once in a while until I call the tech at Vance & Hines and he had me change one of the mode setting now it sounds as it sounded before when I roll off of the throttle.
