Trouble Re-installing Thunderheader 2000 FXDX
Having trouble re-installing my Thunderheader 2-1 on 2000 FXDX. I replaced the stock gaskets with SE flat gaskets. When I line up both ends of the exhaust, it fits. Here's my problem! The front exhaust flange is getting stuck on the threads of the outer stud. I fit the flange around the studs without the exhaust to make sure studs weren't messed up. No problems.
Do I just pull the pipe a little to flush the flange against the head? It's not making any sense. Is it the gaskets? Has anyone else had this problem when installing this system?
Thanks,
Rob
Thanks,
Rob
Yes, I'm lining up the front and finger tightening the nuts onto the studs. I'll continue on to line up the rear and do the same. Once I get back to the front, the flange doesn't slide flush. So I wasn't sure if the pipe just needs to be pulled a little to get the flange over the remaining threads to be flush.
JayStronghawk (05-30-2019)
