Rear brake position
Old 05-04-2019, 07:45 PM
insight75's Avatar
insight75
insight75 is offline
Default Rear brake position
Hi all,
I want to keep my mid controls but wondering if I can adjust the rear brake pedal slightly down to make it a bit more comfortable. Is this possible?
Thanks,
Greg
Old 05-05-2019, 11:56 AM
nevil's Avatar
nevil
nevil is offline
Received 1,036 Likes on 774 Posts
There is a threaded actuator rod near the rear brake cylinder. You'll need a couple of small open end wrenches to loosen the jam nut and adjust the rod.
Old 05-05-2019, 09:10 PM
AJ88V's Avatar
AJ88V
AJ88V is offline
^^^ YES ^^^ What he said ^^^
Old 05-06-2019, 07:09 AM
A#1's Avatar
A#1
A#1 is offline
This is todays projecton my 98 Wide Glide.
I took a quick look at it, i hope its as simple as it sounds
Old 05-06-2019, 07:19 AM
insight75's Avatar
insight75
Thanks for this. I did see the adjustment but just wanted to be sure this was an acceptable adjustment as I didn't see anything in the manual on it. Will give this a shot tonight.
Old 05-06-2019, 07:55 AM
John CC's Avatar
John CC
John CC is offline
Just a heads up. I needed to raise my pedal. I ran out of adjustment and it was still too low. (There's a maximum number of threads exposed.) I then went through a lot of work to extend the rod about 1/2". In the process I removed the foot peg and it's bracket. When I put it all back together I couldn't get the pedal low enough and the rod was about 1/2" too long. I never did figure out what was going on, but I suspect the peg and its bracket were not on correctly when I started.
Old 05-07-2019, 08:54 AM
insight75's Avatar
insight75
Thanks for all the help. I made the adjustment and its perfect. Much more comfortable now although have to get used to new position.
hitthecoast
02-22-2020 01:10 PM
ConeMagnet
09-23-2013 10:35 PM
WideGlideFever
02-09-2013 06:10 PM
ncbeast
05-30-2011 09:16 PM
Popop
10-16-2007 10:38 AM
Quick Reply: Rear brake position
