No rsp from ecm with run switch on!
I have a 04 wide glide fuel pump not priming not getting any spark so it won’t start just turns over and I try checking the codes it just says no rsp from ecm and yes the bike run switch is on all fuses and relays are good and used a test light and shows getting power to all fuses
