What is this part called - 87 :Lowrider
Can I remove this part when I do my next oil change... nothing wrong with it except for the chipping chrome which is why I'd like to remove it.
OR, does this part have some kind of spring loaded gear that will shoot out or get messed up if I remove this. Also what is the name of this part?
What's This ?
The little cover with 2 screws is where the timing used to be set... Can you take that off, sure but it will look like dog sh*t without the cover.
The big chrome panel covers up the cam support plate, cam chest, cam chain with the tensioners, and that is where the oil pump lives. Taking that off would not be a very bright move unless you have one to replace that one with.
I think you need to take it to someone who knows Harleys and have them remove and replace that whole cover.
Beezer34 (04-12-2019)
OP: the small round cover is the ignition cover, nothing will explode or fall out if you remove it, the ignition sensor (cam sensor) is underneath.
The larger chrome cover is the cam cover, all kinds of things under there, and since you asked, removal is a bit involved. You need to do a little reading in the service manual to get an understanding of the guts inside the timing cover (cam, lifters, breather gear).
You asked a smart question...we can talk you through the process of replacing this cover, as long as you have a service manual and a bit of mechanical experience.
You can also install a nose cone chrome cover to hide the peeling https://rover.ebay.com/rover/0/0/0?m...2F122855714801
I`d rather have a beat up looking cover on my engine that put something like on it, that is just plain tacky.
The following 2 users liked this post by Dan89FLSTC:
Beezer34 (04-12-2019),
Greezey Rider (04-12-2019)
