Stage 1 on Monday
RE: Stage 1 on Monday
Falsealarm,
How much is the stealer charging you for doing the install? You might want to consider doing it yourself and pocketing the money. It's an easy enough upgrade. Wait till your tuner comes in then set aside a few hours to do it. Shouldn't take more than about three hours to do the whole thing yourself. And that's including taking the time to read through any directions and study any drawings prior to commencing the work. There are a lot of knowledgeable people on this site that are more than willing to help you through it.
Bart
Bart
The Stage 1 is an ECM burn-in to fatten up the A/F Ratio (according to our local stealership and $200 to boot). It is used with New A/C and Pipes. Not as effective as Some type of tuner (Daytona,TMax, SERT or ?) with or without dyno time.But, then if your only changing A/C and pipes. How far do you need to go? You might want to do somehome work, if you haven't already, and look into a piggyback (Fuelpak, Revtech or ?). Lot's of option's don't limit yourself to the MoCo. Remember, the aftermarket industry is there for us when the MoCo fails, as usually happens.
