Speedo Error 'L IP'
Tim, welcome to the forum from central Texas.
The speedo is reading "tip" which means the bike tipped over or the bike thinks it tipped over. The bank angle sensor (BAS) is reset by cycling the ignition OFF and ON with the bike upright. If that fails, the BAS may be at fault. It is part of the BCM (body control module) or TSM/TSSM (turn signal/security module) depending on the year of your bike.
There is some information here.
If the error continues to show take your bike to the dealer or your Indy for further diagnostics.
Mutineer (02-28-2019)
CoolBreeze3646 (05-06-2023)
Logic tells me the older bikes have the bank angle sensor in the signal /alarm sensor
Now it's in the BCM. So depending on year, root of it could very.
ADpete, Welcome to the Forum. Just as a suggestion make your next new post over in the new member welcome area and say hello.
ADpete (05-06-2023)
I have my bike stripped down to the wiring.
I had the signal/alarm on its side and I found I could turn the fault on and off.
But 😮💨 I still have not fix my original problem.
When I turn the bike off, the location lamp and speedo stay illuminated and occasionally the tail lights as well.
yeah, that is what I found.
Take the key switch apart.
!!!!!create a signature line for
your bike, year, model, and all the code letters!!!!!
zook1065
07-28-2006 11:19 PM
