Hand Brake Question
It sounds like you either need to rebuild your front master cylinder (most likely, super cheap and easy), or your front caliper piston/s have built up a layer of crap and are sticking a little bit (even cheaper and easy to fix if this is the case). Or possibly you just need to bleed the brakes (also cheap and easy).
It sounds like your brake lever is not returning all the way.
Given the age of the bike, the first thing I would do it flush the front (and rear!) brake system with new brake fluid. You may want to rebuild the master cylinder.
Also, remove the front brake lever, clean it and add a thin smear of grease on the pivot point and reinstall.
To check/clean your calipers pistons, remove the caliper from the bike, and place something thinner than the rotor in between the brake pads, like a paint stir stick, or my favorite an old butter knife. apply some brake pressure by squeezing the handle in order to extend the pistons out a little. And then if you have a grove of crap exposed on the pistons this was likely you problem, but regardless now if the time to clean these off, with brake cleaner and a nylon brush. Then gently pry the pads back apart, pushing the pistons back in, reinstall and reseat the pads on the rotor.
Bleed the brakes, either pay, or you already know how to do this.
Rebuild the master, either pay or follow the easy to understand directions that come in the kit, as well as the maintenance manual.
"Also, remove the front brake lever, clean it and add a thin smear of grease on the pivot point and reinstall."
if you remove the front brake lever be VERY careful you don't break the end of the brake light switch as you put the lever back in … it is very easy to do … you will know if you break it cause the brake light will be on all the time …
Received 5,751 Likes
Brake lamp switch cleaning. (Probably the plunger is fouled.) It's inside the perch. And, there's NO cable.
