can't outrun 06 Heritage
Old 10-27-2005 | 11:56 AM
intruder400ex's Avatar
intruder400ex
Default RE: can't outrun 06 Heritage
I still think you shouldn't have a problem walking that sucker down my 04 doesnt have much done to it and I havent had anyone really take me with an american bike and I ride with lots of different people if you have a warranty still the dfo may affect it not possitive though TC would know.
Steve
Old 10-27-2005 | 04:05 PM
Mxjunkie's Avatar
Mxjunkie
if you want stop light to stop light power, get the sprocket to change the gearing in the primary. It's allright for over the road, but from point a to b it made a HUGE improvement on the bikes overall power and get up and go.
when my bike was just a 88 we changed the gearing, intake, carb, ignition, exhaust and there was a few other things, and it walked all over everyones bike! It's all about what mods go togather
for pipes, I would recomend thunder header or Bassani Pro streets, in the 7 sets of pipes we have tried on mine and dyno pulls prove that both these systems offer the best overall power.
Carb, if your running an 88 you can put a thunder slide kit in it. Then once you modify it more you can upgrade to a mikuni.
Intake, you could upgrade the the screamin' eagle.
Old 10-27-2005 | 06:58 PM
2_up_FXDI's Avatar
2_up_FXDI
Ok, I see it says if I have any other ECM modifications I have to remove them before installing a DFO, does this include the Stage 1 re-map? Cause when i got the stage I air cleaner and SEII slipons I had the dealer remap it. But now it has the V&H pipes, do I need to get the remap taken off, or can i just get the DFO and install it right over the remap? Thanks again in advance..
KC
Old 10-29-2005 | 10:38 AM
skottyd's Avatar
skottyd
My DFO resides under my seat, where the wire harness from the ECU (?) plugs into the injector thingy; my mechanic unplugged the harness from the injectors and plugged it into the DFO, and then plugged the DFO into the injectors. If you had a major reason to exersice your warranty, you would merely unplug the DFO, and you have an unmodifieed bike.
Old 10-29-2005 | 10:43 AM
skottyd's Avatar
skottyd
ORIGINAL: 2_up_FXDI
KC
My mechanic said that he wouldn't bother installing a DFO in my friends anniversary FB because it already had the ST 1 mod (intake, remap, exhaust) and that his HP gain would be minimal. However, I don't believe it can harm the bike on top of other mods; your just increasing the flow of fuel through the injectors.
Old 10-29-2005 | 11:56 AM
intruder400ex
Well its not only that it also gives you the ability to tune the bike as if it was running a carb so if you were to add any mods in addition you wouldnt have to worry about a remap every time.
Steve
Paul Mateer
03-18-2017 11:56 AM
chocho1971
Audio Systems
09-16-2016 04:41 PM
MikeZ
10-22-2011 04:14 PM
Cowboybillyboy
07-05-2008 09:54 PM
wvtommy
01-13-2006 12:48 PM
