Pros and cons of putting wide glide front end on 04 low rider
Old 11-23-2018, 08:28 AM
Durham man's Avatar
Durham man
Durham man is offline
Received 1,630 Likes on 1,021 Posts
What size are wide glide fork tubes vs fat bob tubes?
Old 11-23-2018, 08:40 AM
Bob_fxdb's Avatar
Bob_fxdb
Bob_fxdb is offline
Originally Posted by Durham man
are you mistakenly thinking that the wide glide is not part of the dyna family ? Or that the wide glide is not worthy of the great dyna title???
I don’t consider wg as a dyna. That’s me. I know well all hds frames and models.
Old 11-23-2018, 08:55 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
99-05 DWGs were 41mm. Everything from 06-up is 49mm
I think I remember going back and forth with Multi about the DF fork lengths a couple years ago and don't think we came up with an answer back then. I haven't researched it since. Tall Timber may know. He's probably got the most DF wrench time of anybody here.
Durham man (11-23-2018)
Old 11-23-2018, 10:36 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,310 Likes on 1,859 Posts
Look familiar multi??
Yes ... very familiar
Also as chris mentioned above, but doesn't get talked about much in changing Trail is the Trees Fork Tubes-to-Steering Stem "Offset" because it's hard to find "Values" without having a SET. But Reindeer's Thread HERE is showing the OFFSET difference between the 0° (No rake) 49mm FXDC Mid-glide Trees and the FXDL approx 1.5° Trees. Hard to see in the Lower Tree Pic, but in BOTH, the Tubes are closer to the Stem. So even when the FXDL INCREASED Tree Rake and DECREASED Trail, it also Reduced the "OFFSET" which then INCREASED Trail from what it would have been. So the "Final Numbers" aren't as significant as you might have thought.
So using his 2009 FXDC as an example ...
Rake (steering head) 29°
Fork Angle 29°
Trail 4.70 in.
Wheelbase 64.20 in.
2009 FXDL ... (because of simultaneous OFFSET reduction, only .20 Trail reduction and only .40 WB increase)
Fork Angle 30.5°
Trail 4.50 in.
Wheelbase 64.60 in.
(REF: 2009 FXDC HERE ... 2009 FXDL HERE)
Originally Posted by cggorman
99-05 DWGs were 42mm. Everything from 06-up is 49mm
Of course even earlier than 99, but the "Nominal" size would be 41mm
I believe the FXDF Tubes are 25.5" length (No confirmation yet) which is the same length as the Mid-glide Dynas although NOT the Same Tube. I've been in contact with Tall Timber recently in anticipation of getting some good values of various parts depending on how far he breaks them down (Race Tech Parts are coming ).
Originally Posted by chief08
low rider is 28* wg32*...
Sorry Chief (hey, that's fits )
In reference to the 05-earlier models ... Throw away whatever you used for that information.
There's several resources where you can find the correct info. Here's one ... 2004 FXDL and 2004 FXDWG ... 32°
If / When the OP ever removes his tank, he'll see the Neck Rake Value as part of the Neck Casting. Shown below is from a 1996 FXDL Low Rider (same as WG)
Old 11-23-2018, 11:04 AM
cggorman's Avatar
cggorman
cggorman is offline
Always a pleasure to read your posts, Mike. Thanks for the correction and illumination regarding offset difference among Dyna trees. I wrongly assumed they were all (nearly) the same! I know, I know...never assume...
Just to add a bit more evidence, since it was handy...a photo of my neck. Original 99 FXDWG.
Old 11-23-2018, 06:35 PM
Carl '69's Avatar
Carl '69
Carl '69 is offline
'02 FXD with '02 FLST legs in '01 FXST trees. I like the look & stance of the extra bit of rake in the trees & love the way it rides & handles. Can be done with 100% factory parts, retaining factory neck lock function & with the right parts selection, an entirely bolt-on affair. FWIW, I think the Low Riders with Wide Glide front ends look killer with a 130-16 front.
Old 11-23-2018, 09:21 PM
REW13's Avatar
REW13
REW13 is offline
Bike looks good Carl....
And blue... . Bike is still SWEET ....
Blue Bob (11-23-2018)
Old 11-25-2018, 08:17 AM
SmittyFXDL's Avatar
SmittyFXDL
SmittyFXDL is offline
My 04 dyna low rider has a 32 degree rake in frame. Stamped in frame on right side. Only difference Ben low rider and wide glide for 04-05 was the front end.
so with the frames being the same, i could get wide glide trees with built in rake, but wouldn't i need the thicker tubes and lower legs as well? Don't think narrow glide tubes will stay in the wide glide trees right?
Old 11-25-2018, 05:08 PM
beanoboy's Avatar
beanoboy
beanoboy is offline
'Carl' is that a 130/16 front wheel shown in your pics ? Which model H.D. did you get it from ? Thanks...b.
Old 11-26-2018, 02:16 AM
Carl '69's Avatar
Carl '69
Carl '69 is offline
Yes, you'll need the 41mm fork tubes.
Yep. Wheel's off a '99 FLSTC. Headlight's off a '01 FXDWG & shocks are '09 FXDF. The FLD footboard kit is only supposed to fit '06 up, but with the exception of a single cotter pin, it bolted up to my '02 like it was made for it. Definitely a parts bin special. Lol!
beanoboy (11-26-2018)
Quick Reply: Pros and cons of putting wide glide front end on 04 low rider
