Pros and cons of putting wide glide front end on 04 low rider
Old 11-23-2018, 06:19 AM
Durham man's Avatar
Durham man
Durham man is offline
Received 1,630 Likes on 1,021 Posts
I believe the rake in the trees is in the bottom tree only but not sure.
Older wide glides were 32 degrees in the neck-2 in the trees. 06 and up are 34 in the neck - 2 in the trees.
Old 11-23-2018, 06:51 AM
Durham man's Avatar
Durham man
Originally Posted by Bob_fxdb
Honest and unpopular meaning from me: why would you destroy your dyna? Swap it to a wg then.
Note: I don’t think wg is a dyna.
are you mistakenly thinking that the wide glide is not part of the dyna family ? Or that the wide glide is not worthy of the great dyna title???
Old 11-23-2018, 06:55 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Raked trees are matched set. Upper and lower are both raked.
Increased tree rake will decrease trail. 2 degrees isn't much but it's enough to notice. There are many online rake & trail calculators to help inform your choices. Harley cruisers are generally around 4-5" trail, I believe. Plenty of online data sources you can use for reference to other known bikes.
Fork length, chassis attitude (fore/aft lean), neck rake, tree offset, and tire diameter also factor in.
The WG handling character is partly in the rake/trail and partly in the narrow front tire. I'm not a huge fan of the narrow tire where handling is concerned but it does have a look.
Old 11-23-2018, 07:04 AM
Durham man's Avatar
Durham man
The raked trees decreases trail !
Old 11-23-2018, 07:10 AM
Durham man's Avatar
Durham man
R
Look familiar multi??
Old 11-23-2018, 07:43 AM
cggorman's Avatar
cggorman
cggorman is offline
You're right. I had it backwards. Sorry. Editing my original post. Thanks for the correction!
Old 11-23-2018, 07:47 AM
Durham man's Avatar
Durham man
I had it bakewards a couple weeks ago and multi had to straighten me out lol.
Old 11-23-2018, 07:57 AM
Durham man's Avatar
Durham man
Let me ask you guys this,if a stock newer wide glide has 2 degrees of rake in the trees and that sets the trail at 5.1, what would the trail figure be with fat bob trees?
Old 11-23-2018, 08:12 AM
cggorman's Avatar
cggorman
cggorman is offline
According to the RB Racing calculator, with no other changes, it would end up very close to 7"
Old 11-23-2018, 08:20 AM
Durham man's Avatar
Durham man
thank you cggorman, I have been considering this mod but I don’t think it would be wise. Thanks again!
Quick Reply: Pros and cons of putting wide glide front end on 04 low rider
