front springs
Old 11-15-2018 | 05:22 AM
weasel76's Avatar
weasel76
Default front springs
ive just brought some progressive springs p/n 11-1525 for my 2016 wide glide and the harley manual says oil height to the top of the fork is 95mm and progressive says 140mm has anyone fitted these any tips thanks
Old 11-15-2018 | 04:18 PM
John CC's Avatar
John CC
The difference in measurements is usually tied to the volume of the spring itself. The progressive springs probably have more coils and displace more oil, hence the lower level specified.
weasel76 (11-17-2018)
Old 11-15-2018 | 06:18 PM
Dynaglide92's Avatar
Dynaglide92
You’ll need a oil level gauge for precise levels
the measurement is the empty space between the level of the oil and the very top of the fork tube. Make sure the fork is fully compressed to get the right measurement
Old 11-15-2018 | 08:56 PM
DrewNJ's Avatar
DrewNJ
Go with what progressive says for their springs
Old 11-15-2018 | 09:59 PM
crusader1xxx's Avatar
crusader1xxx
Motion pro makes a great tool for this and it’s cheap, find it on amazon....
Old 11-16-2018 | 11:24 AM
sharkey's Avatar
sharkey
Recently replaced front springs on my FXDF with stock Progressive springs. They recommended an oil level range and I found it easy to use a tape measure from tube top. BTW, I went with the lower (less oil) level of stock HD oil and get a great comfortable ride. Also put standard 412’s on back.
Old 11-17-2018 | 05:49 AM
weasel76's Avatar
weasel76
thanks sharkey i was looking at putting 430 on the rear
Old 11-17-2018 | 02:21 PM
sharkey's Avatar
sharkey
Put 430's on the rear of the wifes Low Rider and she says there's a huge difference over stock. I went with the 412's because I wanted the old FLH shock look of full chrome tubes and top.
The Switchback tops snapped right onto the 412's
subgunner
09-26-2018 12:38 AM
vladt
05-16-2009 08:10 PM
drumer66
03-17-2008 08:56 PM
hogbag07
01-05-2008 02:21 PM
ryback
07-19-2007 06:57 PM
