Dyna Wheel Questions
So I scored this set of relatively unmolested low rider mags from a company parting out a salvaged 10k mile 2014 low rider. My plans are to pull the tires and bearings, coat the wheels gloss black, install fresh bearings and tires, and finish piecing together my dual disc conversion. Questions:
- What is the preferred method of coating wheels (powder coat or paint)? I read some people say that the heat from powder coating adversely affects the heat treat of the wheels, and I've seen others say that they don't get hot enough long enough to have a practical effect. I have several other parts I plan to powder coat so this is the route I'd like to go for matching color and convenience.
- If paint is the preferred route, what is the best method to get a long lasting finish? Do I need to strip the existing black paint? What's the best method for that? I've seen some people use self etching primers, some don't, some sand between coats, some don't, etc.
- What's the opinion on the Pit Posse VT102 bearing tool?
- Are the Timken's still the go to replacement bearing?
- I know you're supposed to install bearings primary side first. Is there a defined left/right for the front wheel?
I powder coated my fxdls wheels which are basically the same wheels but factory are powder coated an uglier shade. My buddy who did my wheels runs a body shop that specializes in custom paint and also does powder coating. He prefers doing powder on wheels due to the durability. If doing paint you would need a good high impact clear to hold up. We blasted to remove the powder that was on mine first although not sure it was necessary. I used the pit posse tool kit to remove the bearings. Worked dang good for the money. I do recommend freezing the bearings before install though to make things easier. Also on the front if yours is an abs bike the abs bearing goes in first. If not it is rotor side first but if you have dual disk I dont suppose it matters. Hopefully this answers your questions some. And lastly a before and after of what my wheels look like.
Thanks for the fast response. Yours came out looking sharp. Being able to powder coat the wheels eliminates all the headache tied up in my second question. I was unaware the S wheels were powder coated OEM, I assumed they were painted.
Glad to hear the Pit Posse worked out for you.
Both my bike and the bike the wheels are from are non-ABS, so I'm not worried about that. Just need 2 good quality 6205-2rs bearings.
I've seen references before that on dual disc wheels, like the older 13 spokes, they would have casting letter/numbers on the primary side and nothing on the right hand which is why I raised the left right question. The wheels delivered while I'm out of town, so I'm relying on the pictures from my wife who doesn't know and doesn't care to examine them lol.
How is your powder coat job holding up? Anything you'd do differently?
Thanks, that's good to know. I was definitely planning on having the disc mounting surfaces, sprocket mounting face, and bearing pockets remain un-coated.
The plan is to build my 07 street bob into another one of those basic west coast themed dynas.
Got home yesterday from working out of town. Flipped the front rim onto the other side and found some road rash. Wondering what the opinions are to fix it. YouTube is full of people who work from 180 grit to eventually wet sanding at 1000-2000. I'm less worried about the first picture. The second picture, its deep enough to get a fingernail in.
