Evolution Industries stainless exhaust flanges
Good point. I guess I was also thinking along those lines without really knowing it. Lord knows I've spent more than a little time, money, and effort on polished parts. I was just trying to add contrast with minimal weight and heat-trapping. My dad used to get down on guys with a lot of chrome because he was all about power and speed. If it didn't show results on the dyno or track, it had no value. He had no eye for style, tho. I guess I try to marry the two ideas.
**** weather today and they were staring at me, so I filled the dimples with flat black engine paint. They'll be impossible to clean anyway. Might as well get it over with.
FWIW, a Q-Tip fits in the dimples perfectly if one wanted to keep them clean.
The nuts are ARP# 400-8614 (6pt, 3/8" hex, .612" flange) which are made from "ARP Stainless 300". That's their trade name for 17-4PH. It's supposedly a proprietary alloy, but the specs I've been able to turn up are the same as 17-4PH.
I chose the 6pt just in case I ever have to get an open end wrench on them. Access to the rear nuts can be a hassle and I wanted to make it as easy as possible.
A face centered cubic arrangement of atoms Stainless Steel 300 series is not heat-treatable. But heavy reduction (power dumping), in the cross section, during forging causes a dramatic increase in strength. This is the process ARP uses to make 304 Stainless Steel reach 170,000 psi UTS.
I miss my brother
