Quick for anyone who may use an R&R Cycles intake...
Old 09-28-2018, 07:09 PM
F86's Avatar
F86
F86 is offline
Default Quick for anyone who may use an R&R Cycles intake...
A few weeks ago I got an R&R Cycles Overflow air cleaner setup for my Mikuni. I have it installed, and I've taken a few short rides with it. The instructions say "Synthamax air filters should not be oiled," but it's a little vague... It doesn't say whether they only use Synthmax filters, or whether some kits do and some don't... I've been meaning to call them for clarification, but it slipped my mind and I'm planning on riding a couple hundred miles on Sunday. I would like to properly oil it first, if needed...
The filter has no brand name whatsoever, and nothing to identify it at all. I've looked on the Air Raid site who makes Synthamax, but they don't show a filter that is a similar size (and they also make "Synthaflow" which do require oiling).
If anyone has used an R&R kit, can you shed any light? Thanks!
Old 09-28-2018, 07:16 PM
cdonis's Avatar
cdonis
cdonis is offline
I believe mine came pre oiled. After I clean it I oil it. When I washed it it was No longer red so I assume oil is needed. For what its worth there is never any residue in the tbody.
Old 09-28-2018, 09:13 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,053 Likes on 667 Posts
Its a k&n filter that is made for that air cleaner. It's hat color because it gets oiled.
Old 09-28-2018, 09:16 PM
F86's Avatar
F86
F86 is offline
Thanks for the response. I wouldn't call it "pre-oiled," as it seems completely dry. The filter element itself is a pale pinkish red... Here's where it seems vague in the instructions:
Old 09-28-2018, 09:55 PM
F86's Avatar
F86
F86 is offline
I know it looks like that in the picture, but I've had a gazillion K&N filters, and this is definitely a different filter element material... It's construction is actually very similar in appearance to the images on the SynthaMax website, which don't get oiled. That's why I'm not sure... I'll call them on Monday, I just have to decide what to do with it on Sunday...
Maybe I'll just see whether my old filter fits on this backing plate for a day.
Old 09-29-2018, 08:15 AM
F86's Avatar
F86
F86 is offline
Well, I just spoke with R&R...
Here's the confusion... They used to use these, which never get oiled (SynthaMax):
But they have used these, which do get oiled (SynthaFlow):
The guy on the phone couldn't really say whether they use SynthaMax or SynthaFlow. He did confirm that the filter is made by Air Raid (who makes both of them and has now been purchased by K&N). He said the filter is preoiled, should not be oiled prior to use but should be oiled after cleaning, and that I should ignore this portion of the instructions:
Thanks cdonis and Jason for your input!
Old 09-29-2018, 09:40 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
T, did you happen to get any pics of how the backing plate seals on the Mikuni throat? How is the inside (air path) transition between the two?
I'm also curious about the overall mounting and breather system.
It's heartening to see a Mikuni air cleaner that doesn't seem to use that stupid adapter ring. Maybe someday they'll design a "Heavy Breather" style. The flat filters don't work well for me.
Old 09-29-2018, 11:26 AM
F86's Avatar
F86
F86 is offline
Yes, I've been meaning to do a write-up for a couple of weeks... I'll do so tonight!
Short version: The breather setup allows a decent level of flexibility in terms of setup, the mounting flange definitely looks better than using the adapter from a flow standpoint, but not entirely seamless. I'll post pictures and more detail later, after I'm home from work!
Old 09-29-2018, 11:28 AM
cggorman's Avatar
cggorman
cggorman is offline
Looking forward to it but no rush. Take care of yourself first! Thanks!
Old 09-29-2018, 12:27 PM
HrdNox's Avatar
HrdNox
HrdNox is offline
This ^ K&N has a cleaning kit with oil.Can be found at Autozone.
Quick Reply: Quick for anyone who may use an R&R Cycles intake...
