Brand New Regulator Blowing Fuel out Bypass
Old 09-08-2018 | 04:19 PM
ZachGrove1's Avatar
ZachGrove1
6th Gear
Default Brand New Regulator Blowing Fuel out Bypass
Hello All,
I have a previous thread where I was having fuel pressure issues, where the bike was dying at idle. It looked like the fuel filter was the issue, so I replaced it. While I had the guts of the tank out - I replaced everything in the tank - Fuel Pump, Fuel Filter, Fuel Regulator, and all internal fuel lines. I received everything from JP Cycle, all spec'd to fit an '05 fuel injected Dyna Superglide (K&N Aircharger intake and Dynojet PV-1 tuner are the only mods).
When the pump primes, and when the bike is running, fuel is shooting out of a hole at the bottom of the regulator housing. I know it's tough to see, but here's a video:
Here's an image of the hole on the bottom of the regulator housing:
I threw the bike back together, and rode it a bit. You can hear the fuel spraying inside the tank while riding, and it's a bit sluggish. Any Ideas where the heck I start to fix this?
Old 09-08-2018 | 07:45 PM
Rasputin666's Avatar
Rasputin666
just looks like it's dumping excess pressure like it's supposed to...
Old 09-08-2018 | 09:09 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Looks normal at idle. Excessive IDLE fuel pressure is being dumped out. EFI works under pressure.and the regulator relieves excess pressure.
Old 09-09-2018 | 01:42 PM
ZachGrove1's Avatar
ZachGrove1
6th Gear
Glad this is normal! Best news I could have received.
This is my first experience with an FI bike - and was under the impression that any agitation in the tank is bad. Thanks all!
stu elpaso (06-29-2021)
Old 04-29-2020 | 10:01 AM
Moorea4086's Avatar
Moorea4086
Stage II
Default Zach1
Ever figure this out? I got the same problem. Pulled my pump out and everything hoping to find a bad fuel line
Loc_Tite
General Topics/Tech Tips
04-29-2020 09:31 AM
Loc_Tite
10-14-2018 05:20 PM
belsebub36
Blowers/Turbos/Nitrous Oxide
01-16-2014 02:27 PM
kingtiger88
01-20-2011 08:54 PM
ToBeFrank
Exhaust System Topics
10-24-2007 09:40 PM
Quick Reply: Brand New Regulator Blowing Fuel out Bypass
