Code Pn 001118-01 and bike stalls.
Hope someone can help. I flogged the bike hard this weekend in the canyons and after the engine started shutting off when dipping into low RPMs. To get her home I had to keep RPMs at 2500+ so she wouldn’t shut off. From my understanding the engine was overheating and the rear cylinder shut off and acted an as air filter.
I checked codes and got many:
P0051, P0118, P0154, P1632. I cleaned the IAC and unconnected the O2 sensors adding some anti-seize. Bike seems to run fine, but I haven’t run her hard yet. When clearing codes, I still get P0051 and Pn 001118-01 when I try to clear that code. Anyone know what that means? Thanks.
Codes can be found here...
https://dgcustomcycle.com/tech/harle...es-04-present/
0051 is Heater Control Circuit 02 Sensor Low - I am thinking one or both O2 sensors are going or have gone out on you. I have found that just replacing them is the easiest solution...
