Any decent SERT Maps out there?
I had my bike dyno tuned at my dealer last year and lately it's been running like crap...more backfiring.......went back and they tweaked it but still the same backfiring on decel and runnning poorly when it's humid. So I reloaded map 141NX104-A0.MT6 from my SE disc and the bike runs a bit better but a bit rougher.
So does anybody have any good maps out there for my setup?
2006 1450 SE A/C & Mufflers
25 deg injectors
SE A/C & breather kit
SEII Slip on Mufflers #80258-99a
Any ideas would be greatly appreciated!
25 deg injectors
RE: Any decent SERT Maps out there?
WELL SCREW THE TUNER!!!Went to the office and printed out all the custom maps I have found for the SERT plus printed out the stock SE Map that came on my SERT CD......took the afternoon off and made the same types of small incremental changes to the SE stock map that were common to all the custom ones (one increment at a time)and after about5 or 6test runs SHAZAAM!! I'm in business.......I got my bike screaming again.....Me happy!![sm=bounceybounce.gif]
There's a great SERT HOWTO over at V-TWIN forums.
http://www.*****************/forums/sh...ad.php?t=60576
I give up, guess there's no way to give you a direct link. You'll just have to fill in the ****'s...
ORIGINAL: Drexor69
Also, one of the forum's sponsor sells custom maps: http://www.latus-harley-davidson.com/
i opted to have a custom map built for my UC when I had it dyno'd since i have non-HD add-ons. I use a canned SERT map for my WG with SE AC and SE IIs. Both bikes run great. real issue with the '07s to get the mixture richened up a bit from the stock lean AFR. bike now runs much cooler and stronger.
