Bump starting my Dyna did it screw it up?
okay I'm new here so bear with me bump started or push started my Dyna 08 Fat Bob the other night and went fired up God awful knocking in the engine is there a possibility I've been hurt on or something else and if so is going to hurt for me to start it again
Yes, for sure!
I should've clarified... You're probably out of luck if push-starting due to zero electrical power... But if there just isn't quite enough juice to turn the starter fast enough, or if there's an issue specifically with the starter, push-starting shouldn't be an issue.
Bump start
So you're saying that it would not bend a rod or anything like that right I had a friend tell me that if you instead of second if you did it first it might bend the rod or even break a piston and I'm afraid that's what I've done man it's been a rod because there's a god-awful clanking and I just changed my oil there's no reason I don't have an oil leak mold good
